Ima Robot On Last Call With Carson Daly
Did you pass out before Last Call with Carson Daly aired?
Well, imarobot.net has added the performance to the the download center for your viewing enjoyment. So go and check out Ima Robot perform Alive and
close out the show with Scream. You must be logged into the forums to download files from the download center.
The file is located here:
http://www.imarobot.net/forum/files.php?action=file&id=74
And you can discuss the performance here:
http://www.imarobot.net/forum/viewthread.php?tid=1366
This thread is closed, so discuss in the thread noted above.
[Edited on 2-26-2004 by draconian]
